Bipenut53
Hello everyone,
As many of you know, I picked up a used 3DHS 89" AJ Slick and I was in need of an engine and accessories to complete the airplane. First off I put the airplane together without any equipment installed and weighed it, the airframe came out right at 10 pounds. This gave me a good starting point to make my engine selection decision. I weighed many options including the EME 70 twin, same engine as in my Extreme Flight Extra, the EME 60, and the EME 55V2. My goal was to keep it as light as possible to keep the wing loading down and make it as "floaty" as possible. So after thinking long and hard I decided to go with the EME 55V2 because of the low all up weight of 3.4 pounds including muffler and ignition. That would mean, if I did my math right the airframe with engine and all accessories should come out to around 17 pounds, perfect for what I wanted in this airplane. So here is a short description and specs from Mile High RC:
EME55 V2 is the easiest engine for plug and play. The factories attention to timing on this motor is outstanding and very noticeable, resulting in noticeably better general running and great smooth operation. EME has recognized the short coming of other motor lines and really steeped up quality. Make sure to check out some of the subtle but effective nuances incorporated into this motor. Such as a longer throttle arm on the carb resulting in smother operation and saves servo wear. The mount design allows for shorter stand off's resulting in less vibration, less stress on servos and other components. Are you aware of the reed block mod on the popular China motors, to get smooth air in to the engine? EME is and they designed the reed block in a manner to allow smooth clean air flow.
Specifications:
Displacement: 55.6 cc (3.392 cu in)
Bore: 1.77 in (45 mm)
Stroke: 1.38 X in (35 mm)
Weight: 3.4 lb (Engine - 2.8lb, Muffler - .22lb, Ignition - .26lb)
RPM Range: 1,350-8,500
Output: 5.5 hp @ 7,500 rpm
Requires: unleaded gasoline, oil, ignition battery & propeller
Includes: electronic ignition, muffler, spark plug, gasket, bolts, machined aluminum standoffs, throttle arm extension & mounting template
Suggested Propellers: 22x8, 22x10, 23x8 & 23x10
So I ordered pretty much everything I needed from Mike at Mile High RC, one thing to note here is from the first email to him about what I wanted to do, he was extremely helpful. I had several conversations, including on the phone, with him and when I placed the order, they had the shipment in the mail the next day. It was all very well packed and arrived without any problems, even though the postal service did the best they could to damage the parts. The outer boxes were pretty damaged by the time they got here but the contents were in perfect shape!! Here are a couple of pictures of the way I got the boxes
So I was a little nervous about my parts before I opened the boxes, no need to worry!! Here is a few pictures of what I got and as you can see there is no damage at all to the parts!!
Thank you to the crew at Mile High RC for the attention to detail on packaging my parts!!!
Specifications:
