acerc
Finished sanding the tail feathers and fuse. Got all hot and sweaty and with it getting late in the day called it quits on sanding the wings. Got cleaned up and currently working on the ele/ rudder linkage.
acerc
The ele linkage has been made. The rudder is half way there, the links are on just need some cable installed. But that will hafta wait til tomorrow.
acerc
The rudder pull-pull cables are installed as well as the exit cover plates. The cover plates will need contouring once dry then on to the nose panels.
acerc
Thanks Billy, will do!
The first of three fuse nose panels (two sides and one top) have been fitted and awaiting the wing to cut it's contour.
