Is that on a laminated prop? I could never get that on a 4-bolt beechwood. Lams did not compress as much for me.wesley. said
I set mine at 50 in/lbs for wood. Never had any trouble. I get to that 50 in a couple of steps though not all at once.
Size of prop and displacement of motor make much of a determining factor in torque values?reyn3545 said
I've always gone 50 on a wood prop and 80 on carbon fiber.
stangflyer said
Ohio.AV8TOR said
All this is absolutely true, but doesn't tell you much. The required force is one key, and there is really no way for most of us to know that. The thrust loads on these bolts are negligible. Dominant loads are probably vibration and unbalance loads. Desired load is probably what is required to keep the prop from sliding around relative to the bolts. The friction terms depend on a lot of things, including but not limited to lubricants, thread lockers, number of times the bolt and hub have been used, surface finish and materials of both hub and bolt and ....Ohio.AV8TOR said
Torque is more about the screw diameter and class of bolt. Keep in mind that there are basic number values then it can get real complicated even thread lubricant. Just use a basic chart but it looks like this if you want to go crazy
T= cDF
T= Torque required
F= Bolt tension required (axial load in pounds)
D= Nominal bolt diameter (major diameter)
c= friction component
