For Sale RCGF 30CC TWIN Cylinder Gas Engine (New version with 1/4 32 angled spark plugs)
RCGF 30CC TWIN Cylinder Gas Engine (New version with 1/4 32 angled spark plugs) Brand new in the box, only taken out to take these pics. Call text or email 314-256-9987 or ibcinyourc@hotmail.com $369 shipped
Includes a "FREE" 19x8 Falcon German Beechwood prop, $17.80 value free with this engine.
RCGF 30cc TWIN clyinder 3.7h.p. R/C aircraft engine 19x8 7000rpm (1 min 51 sec)
NOTE: above video is older version!
30cc twin March 2017 revised cylinders with angled 1/4 32 plugs
Twin Brand NEW in the Box, new version with angled/slanted spark-plugs instead cm6 plugs in center of cylinder straight out. Will fit in many more applications due to simple fact they are narrower width.
Super Smooth
With the RCGF 30cc twin , It's small & powerful easy starting, Very good choice for small size twin cylinder engine applications
RCGF 30cc T
Parameter:
Type : 2 cycle piston valve type gasoline engine for airplane
Piston displacement Cylinder (cc) : 30cc (1.83 cu in)
Bore x Stroke (mm): 1.26 in(32mm) x 0.77 in (19.6mm)
Carburetor : RCGF
Ignition : DC-CDI (Computer Controlled auto advance, electronic ignition system)
Power supply: 4.8-8.4V
Maximum Output :3.7HP /7500rmp
Requires: Gasoline, 2-cycle oil, ignition battery & propeller
speed rang : 1500-8500rpm
Gasoline-Version : Pre-mixed Fuel, 25-40 (Gasoline):1 , Recommendhttps://www.GiantScaleNews.com/forums/images/temp/30.gif1
(90% high otcane unleaded gasoline, Import gas into carbon fiber installations valves)
Lubrication Oil : 2 cycle engine oil
Propeller : 18X8 7500rpm (Standard Two blade prop)
Suggested Propellers: 18x8, 18x10, 19x8 & 20x8
Suggested Break-in Prop: 18X8
Sparking plug: 14/32 Type
Cooling System : Air Cooled
RCGF engine package Includes: electronic CDI ignition, muffler, spark plug, gaskets, bolts, throttle arm extension & manual.
Weight :
Engine: 2.03 lb (923 g)
2XMuffler: 2.71 oz (77 g)
Ignition Module: 5.1 oz (145 g)
Total: Weight: 2.53 lb (1145 g)
Technical Data:
Ignition Battery: 4.8-8.4 NiCd or NiMH, 6.6V LiFe or 2S LiPo pack
Gasoline/Oil Mix: 30:1
Replacement Spark Plug: NGK 1/4 32 or equivalent
dle Speed: 1500 rpm/min
Static Thrust:
17.2 lb (7.8 kg) @ 328 ft (100 m) altitude
15.9 lb (7.2kg) @ 5,900 ft (1800 m) altitude
Pipercub55
Super Smooth
RCGF 30cc T
Good Evening:
Would you be willing to ship the 30cc RCGF to me in Canada? I will pay postage and pay via Money order in US funds.
Thanks
Richard
Super Smooth
RCGF 30cc T
Parameter:
Carburetor : RCGF
1
Weight :
Technical Data:
Static Thrust:
Parameter:
Carburetor : RCGF
1
Weight :
Technical Data:
Static Thrust:
Super Smooth
RCGF 30cc T
Parameter:
Carburetor : RCGF
1
Weight :
Technical Data:
Static Thrust:
