I watched a few videos where folks are using polyester dress lining for fabric material. After some searching found silky polyester pongee material that weights 70 gsm. This is about the same weight as Stits Lite at 1.9 ounces per Sq yd or about 65 gsm. The material cost $2.99 verses $11.58 for Stits lite, bought 15 yards, enough to cover two planes for $54 including shipping. Plan to use Mod Podge to attach the fabric.
Work continues on the wing, decided to drill lightening holes in the front and rear spars, when the plane was built holes were added only outboard of the strut fittings. It is a little difficult getting a straight on drill position.
The trailing edge is complete as well. Quite a bit smaller than the original.
An finally the spruce extensions that built in the original construction and worked very well were a little weak, two broke on a hard landing, these were repaired by drilling 1/8" holes into the main spar and epoxying 1/8" music wire. I plan to cut the extensions off and replace with 1/8" thick 7075 aluminum bars that will be screwed and epoxied to the wood spars.
Just about ready to start the second wing.
