Bartman
Defender of the Noob!
I wrote this for the multirotorforums.com site about a year ago and figured some of y'all would find it helpful so I'm reposting it.
In researching a few questions I had on Lithium Polymer batteries recently it occurred to me that it would be nice if we had a comprehensive LiPo battery thread of our own where we could keep the info up to date and provide a central spot for answering battery questions. To that end I wrote the information below using info from the internet and from my own personal experience.
As always, please feel free to point out inaccuracies so that I can make corrections and make the info below as accurate as possible.
Thanks, Bart
[SIZE= 14px]PART 1[/SIZE]
Are you ready to be a LiPo Ninja?
There are a lot of items to be familiar with when it comes to lithium based batteries. We'll establish a few basics and then dive into the more advanced topics. When you're done reading you should be able to size and specify batteries for your multi-rotor helicopter and be competent in handling, charging, and storing your packs.
[SIZE= 14px]FIRST THINGS FIRST, THE THREE C'S[/SIZE]
Before we get started, it's worth pointing out that there are many different types of lithium based batteries but this discussion will focus on Lithium Polymer (also known as LiPo) packs. You may find in your research that LiPo packs are available with a hard case which are generally made for RC cars where the batteries have a better chance of being damaged in normal use. For most of our uses the hard case packs aren't necessary although some FPV or starter quads may benefit from having hard case batteries if they stand a good chance of contacting the ground during take off or landing.
The three basic concepts (the three C's if you will) worth knowing for Lithium Polymer battery packs are
As the heart of our LiPo packs are the individual cells. Take a look at a pack and you'll see there are multiple flat cells stacked together and wired in series.
Each individual cell is rated for a nominal voltage of 3.7 volts. A pack made up of one cell will have a voltage rating of 3.7 volts. 2 cell packs are rated for 7.4 volts, 3 cell packs are rated for 11.1 volts, and so on and so on. Manufacturers designate the number of cells in a pack with the letter S. A one cell pack will have 1S on the label, 2 cell packs will be labeled 2S, and so on and so on. If you can remember that the S stands for sCell count and that the rated voltage is the number of cells times 3.7 volts per cell, then you've taken your first step towards becoming a LiPo Ninja.:victorious:
Another standard designation on LiPo labels is the Capacity of the pack, usually written as a number followed by the letters mah. Mah stands for Milli-amp-hours with milli-amps being a unit of electrical current and hours being time. A 6000 mah battery pack therefore is rated to provide current measuring 6000 milli-amps for one hour. Since there are 1000 milli-amps in an amp you could also say that a 6000 milli-amp-hour pack can provide 6 amps of current for one hour. After that hour the pack will theoretically be fully depleted having discharged all of its capacity. If you discharge this pack at a rate greater than 6 amps then it will last less than an hour. To keep this from getting confusing let's just say that the Capacity number tells you how much electrical power is being stored and when the number gets bigger, the flight times generally increase.
But before you start thinking bigger batteries are always better, keep in mind that much bigger batteries may weigh so much more that they won't enable you to have longer flight times. There's a learning curve involved with determining what will be best for your helicopter equipment but just remember that the mah rating is the Capacity of the pack.
The last of the basic concepts to understand with LiPo batteries is the max Current (or Amps) that the battery can provide. The maximum Current the pack can provide is a function of the pack's capacity. A capital letter C is used on your Lipo's label to designate the max current that the pack is rated for. The maximum current a 20C pack can supply is 20 times the Capacity of the pack. We've already learned that capacity is the mah rating of the pack.
Here's an example, future LiPo Ninja;
Suppose you have a 4S, 5000mah, 20C pack.
The voltage rating of the pack is 4*3.7 volts/cell or 14.8 volts.
The capacity of the pack is 5000 mah (milli-amp-hour or 5 amp-hours).
The max current the pack can provide is 20C, or 20 times 5000mah. 5000 milli amps is another way of saying 5 amps (1000 milli-amps per 1 amp) so the max current is 20*5 or 100 amps.
Picking a battery that is appropriate for your multi-rotor helicopter starts by determining at what voltage you want to run your motors. This allows you to select a pack with a particular cell count (3S, 11.1 volts; 4S, 14.8 volts, 6S, 22.2 volts; etc). Once the cell count is figured out, you can determine the amount of amps the helicopter will draw during normal flight and during periods of maximum throttle which lets you choose an appropriate C rating or maximum current rating. Once these two items (sCell count and max current rating) are in place you can review the range of capacities offered and select a battery with enough capacity (mah rating) to provide sufficient flight times.
Generally speaking, cell count affects battery size in that with more cells the pack will be bigger/heavier. C rating affects pack size/weight to a lesser degree although high C rated cells will be physically bigger than lower rated cells. Because C rating doesn't significantly affect the size of the battery some people say it's good practice to get the maximum C rating that you can afford. I don't follow this line of thinking but some people do. Cell capacity definitely affects pack size/weight due to the fact that as cell capacity goes up so does the physical size/weight of the cells. All things being equal, a 1000mah pack can be half the size of a 2000 mah pack.
With the basics behind us let's move on to other topics worth knowing if you hope to graduate to true LiPo Ninja status.
Thanks, Bart
- sCell count (Number of cells in the pack, represented by the letter S)
- Capacity (The amount of energy the pack is capable of providing once fully charged, designated by the letters mah)
- Current (The maximum amount of current or amps the battery can provide at its rated Voltage)
