zmonster97
Member
I have a Glacier 6s 5300mah 35c battery for my 71" slick. It seems to be doing fine so far. (two flights) Except on the one tumble it made the low voltage alarm go off on my dx8 telemtry near the beginning of the second flight. I think I have it set to 19.5v.
-DJO
Copied from the other forum. Has lots of power, I tested it! It should be fun!
Fully rebuilt and RTF now! :D
Setup is:
Turnigy Park 480 (1020kv) Motor
40A Fli-Power ESC with BEC
11x5.5 APC Propeller
Turnigy Metal Geared Servos (all around)
1800 mAH 3S 25C Zippy Compact Li-Po Pack
AR600 (dual antennas - no satellite option)
Spektrum DX6i
:cool:
Dan
njswede
If the CG is behind the spar, I wouldn't fly it until you've corrected it. The 41" Edge gets EXTREMELY twitchy when tail heavy. Ask me how I know... You want it to just have a slight tendency to tip forward when you hang a thread around the spar. You'll have a struggle if you fly it tail heavy, believe me. The fuse is so short that even fractions of an inch makes a difference.
