Discussion The I’m going out flying thread 2018
Xpress
Try resizing them a little, they are huge!!:spongebob:
I'll have the "slightly" smaller one ready by end of week. The scheme sure does look good in the air.
Appears you are right, didn't notice until I clicked expand and it filled both of my work monitors with one wing panel :oblong:
Xpress
Lets try these, they should be smaller :yesss:
AKNick
Got ready to remaiden the edge. Fired up and purred nicley. Let it warm up for a couple minutes, opened up the throttle and went up to speed, checked transition and ... we’ll shoot it wants to die... in fact it did die. Hmm, wonder if I got something in the carb when putting together the plane. It ran great before, but my last flight it died during a transition from idle to upper throttle... Six minutes into the flight so I think it sucked in something.
Good thing I got a backup! Laser to the rescue!
Are you sure the engine is not a bit too lean on the HS needle?
AKNick
It is. Lol I believe the HS needle is restricted somehow. Flew great on the first flight. Second flight it was acting great right up to the point where it died. Now it won’t transition. Haven’t had to touch the needles on this engine much.
Taking the carb off now to investigate
