Are you running the original version 7950's Paul? Reason I ask is I was afraid I would run into the same problem but was assured when I purchased mine, (7950's) the firmware had been updated. I am not reg'ing them down and they are whisper smooth, quiet and solid. In fact, no reg on the 7954's in the Pilot Edge, no reg on the 7954's in the PAU, no reg on the 40% 260. Everything I have is jitter free.I am running hv servos(7950s) in my 42 center but I had to reg my lipos down with a turbo reg cause the rudder and elev. jumped around on Hv but they don't on 6.5v. Its rock solid now![]()
That will be one unbreakable setup!I have been using the SF Power Expander Pro's since they first came out in my 30cc 50cc and 85cc planes. When I mentioned these to guys back then. They could not under stand why? They referred to them more as a POCKET EXPANDER and thought they were more hipe then anything. I am just starting on a 40 % which will have the Competition 12 Turbo Plus with the flag and Pin set up, an the MKS HV 777 servo's DA 170 and pro-Flow cans.
@stangflyer I bought them all used(Like everything I own) so I am sure they are probably the old ones. I was worried about the decrease in speed and torque because of less voltage but that big plane is awesome to fly as it is! @flycanic that sounds like a nice bird. nice to finally put a face to the name when I met you the other day.Are you running the original version 7950's Paul? Reason I ask is I was afraid I would run into the same problem but was assured when I purchased mine, (7950's) the firmware had been updated. I am not reg'ing them down and they are whisper smooth, quiet and solid. In fact, no reg on the 7954's in the Pilot Edge, no reg on the 7954's in the PAU, no reg on the 40% 260. Everything I have is jitter free.
Same Here @crashflow The Pilot Sbach 40% has been sitting in the hangar going on 4 years know LOL!! The wings had damage to them that I didn't catch at time of deliver had to skin the bottom covering on both wings and repair quite a few broken ribs, then lay the covering back down. They had also ran a fork clear through the fuse Box that just missed the back side of the canopy hatch My mistake. One that I will not ever make again. The guys up in Montana Have a cash pool going on when they will see it Fly. Great to put a face to your handle also. Later Paul.@stangflyer I bought them all used(Like everything I own) so I am sure they are probably the old ones. I was worried about the decrease in speed and torque because of less voltage but that big plane is awesome to fly as it is! @flycanic that sounds like a nice bird. nice to finally put a face to the name when I met you the other day.
