The Snap Turn
Discussion in 'How To- 3D Flying and Aerobatics Flying' started by gyro, Dec 5, 2012.
  1. gyro
    gyro GSN Contributor
    7,806
    129
    63
    Texas
    [H=1]Description of the maneuver[/H]
    content
    [H=2]Level of difficulty[/H]
    content
    [H=1]Performing the Maneuver[/H]
    content
    [H=2]Entering from ______[/H]
    content
    content
    [H=2]Steering[/H]
    content
    [H=2]Exiting[/H]
    content
    [H=1]Common mistakes[/H]
    content
    [H=1]Tips[/H]
    content
    [H=1]Acknowledgements/References[/H]
    content
    [H=1]External Links[/H]
    www.3drcforums.com
  2. gyro
    7,806
    129
    63
    Texas
    I believe they are different. This is a move that Cody will be instructing on I think.
  3. cool. very interested, especially anything that has to do with Cody.
    has problems with the tail whip on the turnarounds thats on wamsys video.
  4. Kris...
    Kris... 30cc
    37
    0
    6
    UK
    No its not the same as Wamsys turn arounds I thinks its this...
    Click
  5. jmart95
    jmart95 70cc twin V2
    166
    0
    16
    ^ that is correct. A snap turn is just an exaggerated snap with a rapid 90 or 180 degree heading change, and the airplane goes from upright to inverted, or inverted to upright.
    Inputs
    upright left:
    simultaneous left rudder, up elevator, and left aileron. Once inverted, right rudder is kicked in to get a true 90 or 180 degree heading change.
    upright right:
    simultaneous right rudder, up elevator, and right rudder. Once inverted, left rudder is kicked in.
    I don't normally do negative snap turns(flying 48 inchers, and I just don't trust them enough to hang in and I can't afford to crash) but it should just be sticks in or sticks out(top corners), then reverse the elevator once upright.
    Cody Wojcik did an awesome video with stick movements on the snap turns
  6. AKfreak
    AKfreak 150cc
    1,393
    0
    36
    The 90 degree snap turn was devloped by RJ Gridder I think. Its a cool move indeed.
  7. [MENTION=2294]jmart95[/MENTION] your 48 will be awesome for outside snaps. I like to snap with high rate aileron and mid or low elevator. That helps a lot to keep from getting to deep in the snap. Also, I experiment with taking out elevator input toward the end of the snap. I gleaned this from Jesky's all things slick video.
    I like to practice outside snap turns going from inverted flight into upright flight, eg R rudder L Ail for a left outside snap, finished with L rudder.
    That being said. My only half decent snap turn is canopy up into a positive Left. They're awesome when initiated down wind.
  8. jmart95
    166
    0
    16
    I say 48's, but right now its just the super vyper, and you need to slow it down a little and whip it around or else it goes about 70 degrees rather than 90, so if you're not on top of it you can snap it out on the exit. I can do upright and inverted in both directions on any other 3dhs plane, and as I get my thumbs acclimated to the vyper, I'm getting more comfortable doing them, but being a hybrid design, the compromise means it's just a little more forced to do it well.
