cdee
Important Links
To Buy - Green Crack Pitts Mini - http://www.twistedhobbys.com/TH-22-EPP-Crack-Pitts-Mini-Green-RCF-Crack-Pitts-Mini-Green.htm
To Buy - Orange Crack Pitts Mini - http://www.twistedhobbys.com/TH-22-...e-Yellow-RCF-Crack-Pitts-Mini-Orange-Yell.htm
Power Combo - http://www.twistedhobbys.com/Power-...ES-DIGITAL-Power-Combo-Digital-Mini-Pitts.htm
Twisted Hobbys' PDF Manual - http://www.twistedhobbys.com/media/Mini Pitts Manual_01c.pdf
RCF Diagrams - http://www.twistedhobbys.com/media/Crack Pitts Mini RCF Manual.pdf
VIDEOS:
Team Pilot: Chris Jewett - http://player.vimeo.com/video/68489033
Team Pilot: Benton - http://www.youtube.com/watch?feature=player_embedded&v=sfQwqQ0EbWY
New Snap Links: How to Install them: http://www.youtube.com/watch?v=pWn7ECPxiiw&feature=player_embedded
Worth Noting:
1.) The Snap Links - These new little gems will make you for get all about z-bends! The glue on to the ends of the carbon push rods much like a z-bend, BUT if needed you can remove them with out distroying anything. In addition to this, they provide a slop free and smooth coupling between your servo and the control surface. They are different, and will require some technique to install, but one you get the hang of it, you may want to use them on all your foamies. RCF does include a couple extra in the kits for you to experiment with.
2.) The Twisted Hobbys' Manual - provides full detail, step by step instructions and HiRez pictures that you can zoom in on. Perfect for use on a table or PC to have along side your build bench for reference.
3.) Newly created Crack Power Combo! Get all the stuff that was specifically developed and test for this machine. The new motors rock on 2s!
4.) Not only does this little Bipe fliy mild or wild depending on your tastes and set up, it's cute too!! But don't let the size fool you, this is not some lame flying plane that was scaled down, although at first glance you may think that it is just a smaller version of the Standard Crack Pitts, it is not. Much research and testing has went into this model so that it would fly and behave predictably, providing hours of ear to ear grinning pleasure!
ENJOY!.
cdee
Important Links
VIDEOS:
Worth Noting:
ENJOY!.
cdee
