Does my guess count?I guess 34 pounds 3.5 oz dry. Do we get the plane as a gift if we guess right on the money!?![]()
Does my guess count?![]()
So how did it come out?SO, how do you think I came out??? My goal was 39# without fuel (with batteries, etc) and my CG is 8.75" from LE (center of wing tube). Any guesses? I'll post the results later tonight.
What paint did you use for the red?
That's it, I'm cutting a corner off your man card! It's worth losing a couple fingers or toes (yours I mean) to not have to wait for a flight report.Now, as we are heading into our second weekend of below zero temps...... to avoid frostbite I will not be doing the first startup of the engine at least a few more weeks![]()
Sorry, I guess I forgot to post that on this site!!! Thanks for asking. I came out 38lb. 15oz less wheel pants. Basically will be a 39.5lb plane and from what I'm hearing from the ZDZ 180 this will be equal to a 35% plane with a DA120 in relation to performance. Sounds exciting!!! Now, as we are heading into our second weekend of below zero temps...... to avoid frostbite I will not be doing the first startup of the engine for at least a few more weeks![]()
I think it's going to be more like a 150 in a 35% plane. One of my ZDZ 180's is in a 46lb plane and it's got mega POWER. You are going to be so happyMight need a throttle cuuuuuuurrrrrrvvvvveeee
That's awesome, I'll try to avoid the curve with prop selection. I know your elevation is as close to negative as possible but what prop are you running as your favorite on the 180 so far??
