SupaTim
This is going to be a work in progress for me as but wanted to share a little info on the new batch of 2014 engines from DLE. I'm fortunate enough to be one of the guys that gets early access to new products from DLE/Valley View RC as well as a few other things so want to make sure and share my experiences both good and bad (if necessary...) These will be on the shelves in the next month so why not get a sneak peek here! :grrreat:
First impression of the DLE-61 is it looks great! First, it's noticeably bigger than the 55 and 55RA. It shares the footprint of the 55RA and looks like the same carb as well. Throttle arm looks updated otherwise all the hardware is standard equipment with everything you need to get it mounted up and bolted together. Includes the 8.4v HV ignition like the RA as well.
Prop bolt pattern is the same as the 50/55/RA so new new jig needed. Opting not to fly at noise sensitive fields has helped me go back to the purist stock muffler/no cans/no throttle curve mentality so one thing I really liked is the updated stock muffler. First, it's included!! Second is that it's angled, both back and in. If you've ever had to cut out that annoying little crescent moon shape on the front of new cowl you know exactly what I'm talking about. I'll be the first to admit it looks a little lightweight and cheap, but as long as it holds and performs that's all I care about!!
I'm headed back to the garage to put together my new 92" 3DHS Edge to carry this big new beast but as I find anything will update along the way!!
