Not to change the subject but I'd like some input on poptops. Mine always just kind of pop and don't spin at the top.
You can do pop tops both ways...I like doing it this way for that reason, you can go right into a knife edge spin and it looks cool.I must do my pop tops backwards. With some speed I pull to an up line then in one motion I cut throttle and go to left rudder while I input a little up elevator, roll the stick to right aileron to down elevator. It really flatens out and spins about 3 times then As it starts to fall I keep left rudder and down elevator in it, go to half throttle and it does a wicked ke spin. Terry thinks it should be my signature move and it turns out pretty cool.
I've got the AW Freestyle 260 30cc with a VV40 twin in it. I might have to try it with left rudder....What plane? Some just don't do them. Others seem to defy physics and do them with very little speed. The 3dhs 87" Extra for example excels at them. So does their Velox, and the EF 64" MXS does as well. But the big 3dhs 89" Slick stinks at pop tops, while the 104 does them nicely. The EF 78" Extra also stinks at them, but the similar sized 76" MXS does them really well too.
For what it's worth I do mine exactly like crashflow describes above this post. Have a local buddy at our field that does them opposite though and uses right rudder and right aileron initially, and then stirs down to up elevator and over to left aileron and up into down elevator.
The key is speed. As much as you can get, and then it's all timing to convert that speed into rotation. If you aren't getting spin, make sure you have the rudder at full throw and also fully pegged to whatever side you do them right as you are coming off the throttle.
Ryan that is funny, I agree with you that some do it better than others. But now I wonder if some do it better left than right! When you say the 89" slick does the poorly, I always thought it was close to best pop top and crankshaft plane I had, 2.5-3 rotations was not uncommon.
