How many of you have had an in-flight prop failure and were there any circumstances that led up to it?? I fly 99.5% carbon props and had a perfectly balanced wood prop explode this weekend while doing it high speed slow roll. Prop was balanced on blades, and hub. I spent more time than usual balancing it because I don't normally run wood. Spinner was also a lightweight fiberglass that was not even close to touching the prop with aluminum back plate and was also balanced.
How many of you have had this happen? Made quick work of the cowl and the canopy instantly exploded in a huge bang / flutter sound. It was pretty spectacular honestly. Landed with a greaser landing but fuse is pretty muffed up. Can tunnel is broken in several places, fuse sides sparated from F-1, several formers broken, fuse sides broken at the start of turtle deck and some signs of damage at the tail. Most crazy thing I have ever had happen to me since I started flying.
