Just put some extra weight up front, aka BIGGER engine.Thanks guys! Now just have to figure out which would suit my 3dhs 106' edge. Would like to try push pull but I believe the edge has a tendency to be tail heavy.
Plan on going with the GP123 on stock mufflers.I think if you go with stock mufflers and enough battery you "should" be able to go push pull.
If it does balance tail heavy, you can shift the engine fwd some, to counter act.Plan on going with the GP123 on stock mufflers.
Hope it doesn'tIf it does balance tail heavy, you can shift the engine fwd some, to counter act.![]()
Totally agree Bart. Last IMAC contest we were discussing this idea. I've often wondered why no one has put the aileron servos in the fuse, using a CF tube torsion rod for the hinge, with quick connect couplings for wing removal. Could have multiple ganged servos all neatly tucked in at the center of mass. Also less wiring.in an ideal world, all of the weight/mass associated with power, controls, structure would be concentrated at the CG making the tips, tail, nose as light as possible so the plane would start and stop maneuvers instantly. i understand the problem with slop in controls but the more we put heavy servos in the tail and out in the wings we move away from the ideal for an airplane that is supposed to be maneuverable.
one more servo in the tail might not make a huge difference but it would be interesting to see how much of a difference it would make if the servos were all centrally located near the CG with the batteries and fuel tank. unless you pull a P-39 then engine is likely staying out in the nose but everything else is a large airframe could be mounted in the fuselage. the challenge is to maintain really tight positive control without slop.
just thinking out loud![]()
