Better than the last time I found an extension that had gone bad. Mine was the elevator extension on a 40 size profile. Had just installed a new elevator servo and a tuned pipe on the motor. Was getting used to how it felt with the extra power and hadn't trimmed the elevator yet. Centered the stick and the plane pitched up so I applied a little down elevator to correct at which point it continued to pitch further and further down until it met Tera firma. Picked up the pieces and a buddy was helping me diagnose the problem. When he would wiggle the extension at the joint the elevator would do all sorts of crazy things. Now I solder all my extensions on.I spent several hours tonight programming a helicopter flybarless unit and a Castle 130 amp speed controller. I had never used Castle Link or programed a governor before and it all went pretty well after I discovered the short extension I was using on the throttle lead to the ESC was bad. Of course it took me an hour to figure that out.![]()
NICE!!!!View attachment 39139
Couldn't help myself I had to put it together to see how it looked up close. This thing is badass. Maybe it's cause of the round fuse but this thing is actually smaller by a little than my 30% Carden cap but it looks bigger
