What did you make with your lathe/mill today?
Not wanting to blow up Steve's lathe thread so started my own. I want to make a die holder for a die that seems to be a size that I have no holder for. I've been using my mini mill to hold the little 2-56 die.
Anyway, to make a correct size opening for the die I found out I will need a boring bar. Well, that needs a holder so here I go.
I'll start with a 1" square piece of steel. Square means 4 jaw chuck and at 8" its heavy. I protect the ways with lumber just in case of an ooopsie.
Centered and drilling out for the eventual 3/8" hole.
Can't tell for sure but it looks like you have a QCTP, if so why did you need to make the tool holder? I just put the boring bars right in the tool holder.
