jtec/radiowave
Hi Everyone,
We have secured a manufacturer for Carbon Gear. It is slightly heavier than Graph Tech use to be when they were supplying gear. It very good quality.
We have it listed on the website in sizes so you will have to determine what size and version fits your plane. Once we see and get an idea of what fits what we will also start to list it per plane to make it easier to order.
We will have several versions ( styles available ) including gear that have a forward sweep. Including Standard gear, Extra gear. We will also have pictures to reference on the website.
Right now we will be building inventory once we see what people are ordering. Current delivery will probably be running several weeks while we get started.
The key measurements we will be needing are:
Base: the measurement across the bottom of the fuse where the gear will mount ( before it curves down )
Height: how tall you need the gear ( not including the wheels )
Spread: Basically the wheel base, How wide do you need the gear to be.
If you have any question prior please go ahead and give Kevin or I a call at 704-799-1658 or email us at sales@jtecrc.com. The website is www.jtecrc.com webpage http://www.jtecrc.com/carbongear.html
Thanks
Al
Thanks
Al
