scruffmeister
Hi guys,
My DA120 is well run in (5+ gallons). I'm having trouble getting it to idle below 1100rpm without cutting - I feel it should be able to go lower. I leaned the low end about 1/8 turn but it didn't have any real impact.
When I ran with cowl off, I noticed that when I flipped choke off about half a teaspoon of fuel was running out of carb leading me to think maybe it is too rich. Engine starts on 6th flip after choke off without fail.
Prop is a 25x12 3-blade Mejzlik. Engine is on canisters, 2x JMB 60mm rear exits. Throttle servo can close fully it isn't and endpoint issue. Top end is around 6400-6500rpm but I've never really done much as the top end as engine is more than powerful enough for my needs!
I'd appreciate any advice, what is a good idle speed for a 3-blade prop on this engine. Where do I go from here?
