Pbilt024
Today I was maidening a 100cc edge with a new DLE 120 on it. It ran up good on the ground, 6100 RPM with a flacon 29x9 prop. First flight, it flew great for 5 minutes, then it died. After landing, it would not restart. We changed plugs, looked at the reeds, made sure it had a spark, etc. The weird part is, you can choke it till there is gas pouring out of the carb and continue flipping and the plugs will be dry as a bone. At no point was I able to get any fuel into the engine from the carb. The reeds opened and sealed up as they should with no cracks in them. Has anyone ran into anything like this before, because even our local engine guru is stumped on this one?
