slowgto
ok, after fixing 3 motors for people this weekend I have a few tips to share with everyone.
1. Needles: Almost everything I have seen is 1.5 turns for both the high and low. Screw them all of the way in, and back both of them out 1.5 turns. START THERE regardless of what is was. I have seen stuff fly on 3 turns out and people claim they cant figure out the gargle. That being said its usually the low that needs to move and it ends up between 1 and 1.25.
2. Fuel: Always use fresh known good fuel... please!
3. Spark: Everything I have and and have worked on uses an NGK CM-6. Please go to your local auto parts warehouse and ask for a few of them. Be prepared to make up a story on how you need the spark plug for a 'top secret' flying project based on a delorian as they will clamor for 20 minutes on the 'little sparkplug.'
4. Spark: put the plug into the boot and ground it against the motor, spin it slowly by hand, do you see spark? If so then your problem is fuel related.
5. Fuel: How was the aircraft stored? With fuel in it? What fuel was used? DID IT RUN RECENTLY? If not rip the carb off and go though it really quick, it only takes 15 minutes and will save a bunch of headaches. Also see #1 check the needles when putting it all back together.
Anyway, that was my weekend. Making gas giant scale motors pur. I am no wizard but I have been abusing them and blowing them up for a while. Anyone want me to do a basic tuning tips thread?
