MTW canister - header length?
I've got an MTW 110TD to use with my DA70. I'll be using it with a two-into-one manifold, but can anyone tell me if this canister is sensitive to manifold length? I'd like to adjust the length of the single pipe if possible to get the canister where I want it.
(Unfortunately MTW are now closed until 11 Jan, hence asking this question here)
Ditto on @Jetpainter . These headers come in short and long drops. That's 70mm and 90mm respectively. I'm guessing but if you do have to adjust length for the MTW can I imagine you would have to increase the header outlet a bit. Probably get a little longer Teflon coupler about 3.5"long instead of the 2.5" length that couplers normally come in. I would not recommend cutting the header outlet itself because it is just long enough to form back in to a nice round outlet to fit the coupler.
