xCrashNBurnx
I started building my 3DHS Extra 330sc and notices an issue on one of the wings. When I went to hinge and glue the aileron to the wing, I noticed a pretty significant hinge gap at the tip of the wing. Anyway, I wanted to get this question out there because I'm anxious to have this build for memorial weekend and I know this is a busy time for 3D Hobby Shop. It can take a while to get a response from them sometimes. Anyway, should I be concerned? Will it effect the flight performance? Rather than have one large gap at the tip of the wing, should I adjust the positioning to share the gap at the root of the wing? The downside is that this will make the gap pretty tight in the middle of the wing. I've seen warped wings and ailerons before but most with a twist that can be taken out with heat and counter twisting. I looked the aileron over pretty good and it's not twisted but it looks like the leading edge is bowed.
Just to be though, I wanted to say that I've built several 3D planes, from a variety of manufacturers and I went about this process the same as I always do. Push the aileron all the way into the wing. Check for alignment at the root and tip of the wing. Then, deflect the surface in both directions to achieve the proper hinge gap to allow for full deflection without binding. I would appreciate any suggestions or advice.
Thanks
Thanks
