Notorious B.E.N.
I got my EME 70 fired up today. I will say it was not easy to get running the first time.
Some manufacturers run their engines before selling them and some don't. This engine was oiled pretty well so I didn't drop any 2 stroke oil in the case before starting.
After I finally got the motor started, I just let it run at a fast idle on the ground for about 10 minutes. I did a few run ups in that time and it definitely idled better than when I first started it. I had to richen the low end to get it to run and it was too rich. Before the first flight, I leaned it just a little and let it run for a few minutes once again at a high idle just to make sure everything was OK. The first two flights were short (I.E. about 5 minutes). The reason was just to make sure I wasn't overheating and damaging the motor and also I was just wanting to listen to it in the air to see where I needed to go with tuning.
The second flight was short just because I was tired thanks to work and just having trouble focusing so I decided to land instead of risking the plane. I had leaned the motor a little bit more before the flight and it sounded even better. I did a few short straight up climbs and some other brief moments at full power.
Question is what do you guys think?
What would you change?
I am just thinking out loud in case anyone else is curious how to treat a motor that is not pre-run by the seller.
