BRAND NEW from Hitec / Multiplex USA the ePowerBox 50A power supply!
http://www.servocity.com/html/15v-30v__50a_power_supply.html#.U6CDFvldV7s
To complement their growing set of DC/DC chargers, Hitec is proud to introduce the ePowerBox50A power supply. It provides 50 amps of current input voltage range from 100VAC to 240VAC and an adjustable output of 15-30 VDC. Whether you are a demanding racer or pilot, the ePowerBox 50A delivers the power you need whenever you need it. Its easy-to-read backlit lCD screen displays voltage and amperage output clearly and conveniently.
Features:
-1200 Watt, 50-Amp AC/DC Power Supply
-Adjustable DC Output Voltage 15 ~ 30V
-AC Input Voltage 100 ~ 240V
-One 50-Amp and Three 10-Amp Output Ports (with On/Off Switch)
-Two 5V USB Output Ports
-89% Power Effi ciency
-Active Power Factor Correction (PFC)
-Dual Smart Fan Cooling
-Dimensions : 12.0 x 6.7 x 3.3 in (305 x 170 x 85 mm)
-Net Weight: 6.8lbs. (3.08kg)
To take full advantage of this power supply’s 1200-watt power capability, the output voltage should be 24VDC or higher. The actual amount of output current fed to the load is limited to 1200 watts. The chart below shows the actual wattage and amperage available at each voltage setting.
Features:
