NEW Hitec Servo! HS-488HB
ServoCity
ServoCity
GSN SPONSOR
We're excited about the NEW HS-488 servo! It's based around the ever popular HS-485HB, but with some noteworthy updates!
Click to view additional details
AKNick
$18/0.18/6V/83ozin/3pole ferrite/karbonite.
What's interesting is the absence of a phillips head screw and the use of an allen head!
Also 25 tooth spline like Futaba... Is Hitec going this direction instead of the 24T?
You may want to ask @Xpress. But if I remember correctly, Hitec did in fact adopt the 25 tooth spline technology. And the allen head has also recently been added. Just increasing the ever popular Hitec servos to a more appreciated and desired servo.
Xpress
This is a special servo that will be exclusive to ServoCity. The only difference between the HS-485HB and the HS-488HB is the HS-488HB has a 25T spline and comes with an allen head screw.
So what you are saying is, it is the only one with 25t spline and Allen screw?
ServoCity
ServoCity
GSN SPONSOR
The HS-488HB servo is very similar to the HS-485HB, but the differences are:
  • 25T spline like many other manufacturers use
  • Socket head servo screw with larger diameter threads for better holding power
  • no mechanical stop in the gears
  • no mechanical stop in the potentiometer
