Prop bolt circle question
Vernon Smith
I'm in the process of making heavy washers for the DA 60 and 70. I market these to facilitate balancing the plane by placing the added weight as far forward as possible. This reduces the all up weight increase for the airframe to a minimum. My question is, does the DA 50 use the same 30mm bolt circle as the DA 60 and 70?
Vern Smith
White Rose Engineering
Whiteroseeng.com
Vernon Smith
We will chuck one up in a lathe and face off the front to get most any weight you want. There will be a $20.00 charge to customize the washer. I'm sure you think this is expensive but to set up the lathe and cut the washer plus debur the holes takes some time.
Hey, Machine shop prices here that's a "steel". Thanks.
