When you fly giant scale aircraft you have a choice of engines and power systems. When it comes to aircraft with round engine cowlings however, nothing beats the sound and performance of a radial engine.
Most giant-scale airplanes feature an engine box built into the fuselage and secured at multiple points for strength. The Hangar 9 De Havilland Beaver is no different. The length of the Saito 33R3 radial engine (with the included mount) is longer than that of the recommended Evolution gas engine, so the position of the engine box has to be adjusted. I measured the Saito’s length from 1/4 inch behind the propeller to the engine mount. I then installed the cowl using that same distance. I marked this dimension with a pencil on the inside of the cowl. This showed the new location for the firewall. I then cut away the excess material from the front of the engine-box structure so that the engine (attached to the firewall) could slip into position. A Dremel Moto-Tool and a cut-off wheel did the job. A sanding block smooths the edges nicely.
I made a firewall template (including the engine mount bolt hole pattern) and worked out the positions for the throttle arm, carburetor venturi, and the fuel and vent lines. I then fabricated the new firewall, laminated together using three layers of 1/8-inch plywood using 30-minute Zap epoxy…
MODEL AIRPLANE NEWS PREMIUM members can access this article and many others highlighting amazing techniques, RC airplane builds and projects. When you become a member, you’ll get instant online access to our back-issue archives, the latest Model Airplane News Digital Editions, all of our newsstand-only special issues, and much more.
Membership includes exclusive access to our enormous collection of RC information.
http://www.airagestore.com/membersh...f-exclusive-member-access-for-only-24-95.html
- 7+ years of digital editions of Model Airplane News
- Flight Journal and Model Airplane News special issue digital editions, previously only available on newsstands
- Free access to our magazine app through the iTunes Store – get Model Airplane News on your mobile or tablet device
- Contests & giveaways only for members
- 30 years of Model Airplane News archives
- 10 years of Electric Flight archives
- 5% off ALL Air Age Store purchases every time you shop
