Redwing RC has Smoke - Miracle Smoke Pump!
SleepyC
Miracle Smoke Pump
Outfitting your plane with a smoke system can be a really neat feature. Whether you are flying solo or in formation, a smoke system is a sure way to impress your friends at the field or the crowd at an event.
The Smoke Pump from Miracle is a great choice because it features two high speed oil seals and a brushless motor that provides and constant flow of smoke liquid so there is no risk of causing sparks. Included with the Miracle smoke pump is one 10a ESC with banana plug that is pre-installed. Not only is this smoke pump easy to install and easy to use, but it also looks great. Made of Miracle RC's signature high quality 6061 anodized aluminum with CNC finish, you can be sure that you are putting a high quality accessory in your plane.
Specifications:
--Weight: 3.32 oz (94g)
--1100KV Brushless Motor
--10 Amp Brushless ESC
--Input: 2-cell lipo or Li-FE (6-cell NiMH)
--CNC processed 6061 anodized aluminum
--Fuel resistant fiberglass filled nylon gears
Miracle Red Smoke Pump
$65.00
www.redwingrc.com
3D-Joy
Looks great. I have yet to have a smoke pump that does not leak from every seam. It looks like they went an extra step to avoid that. And the price is right too.
