From Tactic:
The FPV-RM2 FPV Monitor is the ideal accessory for our FPV-G1 Goggles, whether you’re interested in radio-control models or aerial photography. A 4.3″ backlit color LCD screen gives you great picture quality, while the 40-channel, 5-band 5.8GHz receiver is optimized for pro FPV racing. The auto-scan feature makes it easy to find the clearest channel for FPV viewing. A micro memory card slot lets you store, edit and upload your videos in the highest quality, while a 1.5 hour run time and USB charge port add to the convenience.
Features:
- 1.5 hour run time
- Manual and auto-scan band/frequency selection
Includes:
- Backlit 4.3″ (109mm) color LCD monitor
- 40-channel, 5-band 5.8GHz receiver
- 1S 3.7V 1400mAh LiPo battery
- RP-SMA whip antenna
- Sun shield
- Micro memory card port (up to 32 GB)
Requires:
- Micro USB charge lead
Specs:
Monitor: 4.3″ (109 mm) color LCD
5.8GHz Receiver: 5 bands (A, B, E, F and R); 40 channels
Antenna: RP-SMA 3dBi whip
Receiver Sensitivity: -90db
Screen Resolution: 480×272
Format: NTSC/PAL (auto-adjust)
Micro Memory Card Port: compatible with cards up to 32GB
Battery: 1S 3.7V 1400mAh LiPo battery
Operating Voltage: 3.6-5.5V
Run Time: 1.5 hours
TACZ5152 – $74.99
Visit TacticRC.com
See more posts about Tactic
