Thrust line adjustment?
3Dchief
It depends on the plane, but usually a small adjustment makes a large difference. Start with 1/8" washers, fly it, then add more if necessary.
Once you get it how you want it, just leave the washers in place, no need to modify the plane unless it is 1" or more.
So for up thrust its 1 shim on the bottom of each post. to do right you add 1 shim on both left posts. So this way you have 1 shim on the bottom right 2 on bottom left, and 1 on the top left. This method prevents any load on the crank case that could occur, and works really well. You can get very close just make sure the shim are all the same size that u add.
