Trailers, Toy Haulers, Etc!
wfahey415
3DRCF Moderator
Me too!! Well done!!! Now time to get to work on the new arrival!!
Yak is currently taking up space on the work bench. I also need to get the motor and servos for the Edge. Plan is to put a DLE 55RA in it with XQ4020 servos. Electrodynamics A123 battery, charge switch and opto-kill switch. That is how I have the Decathlon and Yak setup and it works very well. There is a white light showing receiver is on and a red light showing ignition is hot. I also like being able to kill the engine with a simple flip of the gear switch. I am thinking about upgrading to a Rotoflow tank too. I have heard good things about them and it is almost impossible to find a Fortitude tank these days.
Bipenut53
That sounds like a great set up, that is one reason I used the Fromeco Wolverine switch it has a blue background light when on and the optikill switch has a red led and lites when ignition is hot. Another reason I went with the Wolverine switch is the fact I can run two lipo batteries into it and have two power leads coming out for redundancy and also it draws the same amount of power out of each lipo as I fly, if one were to fail it would shut that one down and draw off the other and if the switch fails itself it fails on..... I use a LiFe 6.6 battery for my ignition and all works well!!
