3dbandit
Sneak peak of my night flying rig!!!
SnowDog
Anyone ever fix a joiner on a 70" Slick? I got really low in a harrier and was tail dragging. Plane starting dipping to the right and broke the joiner and pulled the robart hinges out. I know how to do the hinges but IDK what I should do with the joiner???
I have a joiner for the 71" Slick that I am currently building (my next step is to hing and glue the elevators together, so you caught me just in time). You can't have it, but I can give you the dimensions of it if you want to build one yourself, as others have suggested.
Let me know if you want the dimensions.
3dNater
3DRCF Regional Ambassador
I would like the dimensions even if he doesn't ;) Mine could use to be replaced as well.
SnowDog
Ok, well, here are the dimensions:
width: 208mm
height: 10mm
thickness: 4mm
obviously, the front edge is beveled to match the bevel on the leading edge of the elevators.
3dNater
width: 208mm
height: 10mm
thickness: 4mm
So basically cut out a rectangle and bevel with sandpaper. The whole thing should take less than 30 min including setup time.
