Scale 50% Dalotel 165
the picture with the rx, I will be mounting here temporarily, although it will go there but camouflaged. and this is getting setup for the maiden test flight around mid to end of August. so right now a lot in the wiring to keep everything invisible, not an easy task also to start installing ignition modules, and fuel tanks
Last black trim done but will need a bit fixing, no big deal, and cut out the hole where the electrical will connect from the wing to the fuse
today got the fuel lines installed through the firewall and another gromet for the electrical such as ignition wires, and two servos to be in front of the firewall, also you will notice, on the side of the airplane, its not a new spar but an adapter to be able to sit the plane done , it will have small wheels
