Cool The I'm going out flying thread 2017
BalsaDust - If that is Bright Yellow Ultracote, I've got some PPG Concept paint that matches. You can mix just a tad and use a brush to touch up if you don't want a new cowl. Already appears to have been touched up near the cowl inlet. Don
Thanks Don. I'm not sure what yellow it is. It's what ever 3DHS uses.
Well had another good day at the field but just to windy to try out my new 500cc pattern plane. Built a couple years back but just never got around to finishing it. Well it made it to the field but a 90 degree cross wind at 20mph plus was not the right stuff for a new and never flown plane so it stayed in the car and I flew my Pro260 for the day. Waiting for a better day.
Xpress
What a fun weekend. Went out and 'test flew' the new Multiplex Easy Glider 4 RR, took the girlfriend out and let her get some more stick time on her Multiplex Heron, and of course got some more stick time in on the Pilot Edge. I've got the CG on the Edge just about where I want it :)
Yakman
Xpress your shenanigans would fit in, and your planes would look far better [i think] with the Black Hills of South Dakota in the back ground. 24th thru 27th Black Hills Air Rally.
Xpress
They'll fit in far better at the Tri Cities Huck that I'll be at August 31-Sept 3 :D
