Built me a removable upper deck today for my camper shell. Nothing heavy duty but more than sturdy enough to haul a couple extra planes to the field.
. Been 3 months now since I ordered it Put together a Multiplex FunJet Ultra last night that I've had hanging around forever. HS-70MG's in the wings, still trying to think up a good power system for 3-4S...
Try a 1000KV in-runner on 3S with a 5x4.5 APC. Ballistic! for 3S. Use a 50amp ESC
1000kv is a bit too low on the rpm, that would swing a much larger prop very easily. We suggest a 2900kv 35mm outrunner with an APC 6.5x5.5 prop on 3s, I have a 2600kv outrunner I need to swap shafts to get to work but I think it should fly it well.
. And now that I think of it you are absolutely right about a bigger prop. I think it was a 6x5 not a 5x4.5 but I did have a 5x4.5 on something??? Dag gone it just can't remember.... may be the other popular speed wing. Messed around with them for a season or two I had a 35mm 1000kv 5x4.5??? on 3S 2000mah on one and it zipped pretty good 110+-mph. You must be looking to break 160mph and out run the radio signal. And now that I think of it you are absolutely right about a bigger prop. I think it was a 6x5 not a 5x4.5 but I did have a 5x4.5 on something??? Dag gone it just can't remember.... may be the other popular speed wing. Messed around with them for a season or two
. Loads of fun.
I think you need a cheeseburger to get your brain trackin straight again
35mm 1000kv outrunner is what's in my 48" Slick, swingin' a 13x6.5 on 3S 2200's.
The stock powerpack for the FJU runs a 35mm 2900kv outrunner on 3s, and swings a 6x5.5 prop.
http://www.weekenderwarehouse.com/funjet-ultra-power-pack/
. My mind was a terrible thing to waste
. I need to go take a nap now
.1000kv at fully charged 3S 12.6 volts is 12600 RPM. At 4.5" of pitch that's about 54 miles an hour. Now @ 2500KV, now your talk'n.I had a 35mm 1000kv 5x4.5??? on 3S 2000mah on one and it zipped pretty good 110+-mph. You must be looking to break 160mph and out run the radio signal. And now that I think of it you are absolutely right about a bigger prop. I think it was a 6x5 not a 5x4.5 but I did have a 5x4.5 on something??? Dag gone it just can't remember.... may be the other popular speed wing. Messed around with them for a season or two
. Loads of fun.
Kelly, the cholesterol from all those cheeseburgers is cutting off the blood flow to you noggin.Ask me how I know this....... but since I paint and eat cheeseburgers I probably wont remember.
. But hey....A nice nap seems to make things all better. Now where did I put that cheeseburger???
