Did not think about looking there but just did. It would fit in my box so I may just order one. Thanks.
If I may suggest @acerc buy two 500 units. It is easier to live with and just as handy when you just need one. And if you want the two 500 units can be locked together, they have built into them tabs that allows you do that. That is what I have done.
I never charge just one battery even when charging the Tx as I use two, but, after reading the specs two singles would yield two cooling fans of 13cfm's rather than one. But on the other I never charge above 1 amp so it would not need the added vent. So the one unit at $25 less would be the smartest route for me I think.
I needed more 1mm thick carbon fiber sheet to use as the base for the aileron servo mounts in the Ultimate. I only had enough on hand for 2 of the 4.
Woo Hoo, the wood rasp showed up today. I know most of you probably don't get just how delighted it makes me but I use these a lot and the last set was at least ten years old. Two of them got wore in half and the remainder was almost to dull to say they worked. I guess this being stuck to the house, for the most part, is turning out good as I am replenishing stock and getting things I had wanted but never bought.
I know the feeling. Don’t own any rasp but was so excited the day I finally got a set of quality wood chisels.
I must say I always enjoy buying tools and mean quality tools none of this stuff from China. Always try to buy the tools from Europe. But one of the best lessons I had was from old gentleman and I mean old he was a master carpenter, he would give the odd class in wood work. He gave 2 day class in wood chisel sharpening boy was that a treat best two days I ever spent in a class. Bought all the stuff he recommended and never looked back. A swaying he had it does not matter what steel you have if it has the correct wedge and edge it will do the job and how true that is.
