thebluemax
Nothing good unfortunately. My first mistake was trying to clean up the shop to make some room and the my second mistake is I knocked my H9 BF-109F2 with a Laser 100 in the nose off the bench and busted up the cowl. I know it is a long, long shot but I am trying to find a replacement. I can fix this one but there is no way I can match the paint. Trying to get this off the bench so I can start building my winter project which is a Ziroli Ercoupe.
Got all the servos mounted and set so that I can get a minimum of 130% throws on all of them . The steering Servo is in and done now all that needs to be done to finish the throttle servo install, which always takes the longest to get it to work correctly and the off set not off to one side.
We wanna see the Ercoupe build.
Ok it’s DONE just needs some fuel and a battery, and spring.
The worst thing is that it is still January it may still take 4 to 5 months before I can fly I really, really, really need to find something to build. Need a kit of some sort to build 30cc, getting desperate.
You use an "Elevon" mix with the ailerons using the elevator as the master channel? Looks AWESOME!
