Cleaned up a mess which had been months in the making, and can actually see the tables again.
Then, made some progress on the Python over the weekend.
Looks good, just the one part between the red and white looks distorted or like it was painted or is that just the picture.
Covered the a couple of cowls not the easiest job to do
It’s probably a combination of both. I’m no magician with covering.
@AKNick Things should get exciting at home. A buddy of mine had ended up getting a few new printers and no longer using this one so doing an even swap the printer for my old Taranis X9D that he wants. Its the Anet A8 upgraded to the AM8 with Bowden extruder, dual power supplies, and BL Touch installed. Only thing wrong with it is the Thermistor he says will stop working when the gantry is traveling up so I'm thinking a loose or broken wire somewhere that should be easy to fix. Will be fun to have one at home to play with.
