Got a delivery today. I ordered a hardware pack for the X Cub 60 for some of it's contents.
These are the parts I plan on pilfering. The main reason I picked it up was for the wing strut components. But I will also use the tail brace wire kit and probably the pull-pull system it included. I could not find any 6mm blind nuts, so I just picked up some 6mm nuts and I'll counter sink them in a block of wood, then glue it in place. I had a set of strut mounts from a crashed Decathalon that worked out for the Cub. The strut pins in the hanger 9 hardware package will work out for the strut mounts as well.
That’s the rudder light and servo exit fairing’s for the wings that come with the hardware kit! I think the rudder light will be too big for me to use though.
Need some help guys. I'm trying to find a 4-40 pushrod in the 40" range for the elevator. Can't find anything on line. Do any of you know where I might find such a thing?? Spring steel would work as well. .094, 3/32".
I would not use a 4-40 rod for the elevator linkage without having it inside a semi-close fitting tube. With that said I built a 30CC size Staggerwing ARF that came with 4-40 rods with tubes installed in the fuselage, came out tail heavy so I replaced the steel tube and tube with these carbon fiber rod kits. I used these again on a Bryon Glasair or the elevator, they work well.
