Scale Scratch built Grumman FM-2 Wildcat
flycanic
IMG_3650.JPG IMG_3651.JPG IMG_3653.JPG IMG_3655.JPG IMG_3658.JPG IMG_3661.JPG IMG_3674.JPG This plane My older brother and I liked a few years ago. I took the plans I bought from RCM plan service, for a 40 size glow plane. My Uncle Bob enlarged the plans and came up with this 105" FM-2 Wildcat cat I helped on building when I went on vacation. He past away last year so Yakman and I will be finishing this in his Honor. The gear he designed from the plans and I did the welding We used square aluminum tubing and brass tubing for the front and rear wing tubes. He designed the captivating bolt system. Plane was started in late1990.
@Decal Dennis, @49dimes, @bigblueswope, @stangflyer, @Bartman
Bartman
Defender of the Noob!
i might be needing a similar set of gear like that if i can sufficiently grow a set and get to making a plan of attack!
what scale does a 105" wingspan make it? and how much of a windmill will it need up front?
flycanic
IMG_3682.JPG IMG_3685.JPG The Engine we were going to use was the OS BGX 1 2 cycle glow, or a Quadra gasses. I just weighed it tonight and the all up frame work and gear came to 17lb. 5.7oz. I am considering an EME 120 for this one. Flying weight I am going to try and keep it some where around 27lb. to 29lb. I we haven't decided how much scale detail we are going to do. Thanks for all the great comments guys. As far as what Scale, I have no clue, I just told My Uncle to size it up to some where over 100" and this is what he came up with 105" FM-2 LOL!! More to come
View attachment 12002 View attachment 12003 View attachment 12004 View attachment 12005 View attachment 12006 View attachment 12007 View attachment 12008 This plane My older brother and I liked a few years ago. I took the plans I bought from RCM plan service, for a 40 size glow plane. My Uncle Bob enlarged the plans and came up with this 105" FM-2 Wildcat cat I helped on building when I went on vacation. He past away last year so Yakman and I will be finishing this in his Honor. The gear he designed from the plans and I did the welding We used square aluminum tubing and brass tubing for the front and rear wing tubes. He designed the captivating bolt system. Plane was started in late1990.
Coool.....I've always like those planes. A warbird of that size under 30 pounds would be incredible. Now quit goofing off and get that thing built. :yesss:
