3D Yak rebuild
mikeh
I have most of the work done but I thought I would share my progress. CAM00078.jpg CAM00082.jpg
mikeh
Stabs ready for incidence. All that coring and I don't think I will do it again. Alot of work and the weight Savings are peanuts.
mikeh
Vertical stab is ready for glueing after incidence is set.
mikeh
A couple pics of the wings, coring, sheeted, and incidence set. Also checking for squareness.
mikeh
All control surfaces cut loose. Thought I would play with the split ailerons on this build.
mikeh
Foam belly was cut, I made it a half inch deeper to make room for the pipes.
mikeh
Motor and pipes were mounted and the belly all glued up. I also moved my rudder servo to the back in front of the tail wheel.
mikeh
Looking from the inside, I put down clear Monokote. I have some louvers coming from taildragger rc. These will go on the bottom beneath the pipe mounts. I need to be able to put on the silicone bands.
