ROLLERMAN
With the fin in place and the TE done it was time to start adding on the bottom decks and turtle deck. Sorry but I failed to take pictures of the process. After completing the decks I started on the hatch, THAT!! Is a ton of work. Gota have some kind of plan. On the 118 I built I caught hell adding the recess on the outside part of the frame after I had it all glue together, on this one, I used my Dremel to add the recess.
ROLLERMAN
So, just as I did on the stabs, I added some hard points to the side of the fuse where the canopy screws are located.
ROLLERMAN
I used the same set up on the 118 and I never had one come loose and that was without using any blue locktite. I do believe they hold better.
ROLLERMAN
Now that I have the hatch frame completed, I can line up the canopy and trim it. I also worked on the dash panel, I added more detail to it, and this was fun to do.
ROLLERMAN
Hey guys I have a question. I want to paint the inside of the hatch and I don't want the grain showing on the wood. Recomendetions would be great. I saw where Trev in Canada uses Eze-Kote. Was wonering if there is anything else I could use from like Home Depo or Lowes.
Thanks in advance.
