BOTTOM HATCHES
As I am going to be putting the Valach 4 stroke engine onto this airframe, I do not have to use the bottom hatches for either a canister or pipes.
I also plan on using a much more simplified way to attach the lower wing, so having access to the back hatch is not necessary.
I made from 1/16 inch birch plywood two hatches that go over these areas so that they will remain clean, yet I am able to get inside if needed to get at my wiring.
I saw one Beast last summer that after a year of flying was very dirty inside these hatch areas, these open areas also produce a lot of drag (although that might not be important for this plane).
As the front hatch will house the carb of the Valach (pictures to come) I fuel proofed this area in case of the carb wants to spit out fuel. I also added some aluminum louvers to help remove some of the heat from the engine that will migrate back here.
View attachment 42672 View attachment 42673 View attachment 42674 View attachment 42675
