AEROSHELDON
Why would ailevator make a difference?
I never use Ailevator. I always assign both elevators to "elevator" Same stick and trim. In the AFR menu you can use a spline curve on one of the halves to match the position very precisely using a 17-point curve..
Of course getting you mechanical setup as close to perfect as possible helps. Then match centers with sub-trim and the AFR menu again to match end point. You can also use the ATV.
That is with the 14MZ/18MZ/18SZ.
Hey Kelly,
Let us know how you like your 18SZ. Even though I haven't had a chance to fly with it yet, I'm going through my 14MZ programming functions and I really like the way everything works. It is very similar to my 12Z but easier. Thankfully, because it took me FOREVER to learn how to program that radio after moving up from the 9C. . . . .![]()
