103" Extra 330SC Building, Flying, and Questions
It's only bad on wide open and wide open up lines I put one washer between the stand off and firewall yesterday will check it out next time I fly
I had so much trim in it I e time trying to get it to act right it was crabing lol so it's a thrust issue I believe I have put one washer on the left side to give more right thrust will see if it helped next time I fly
Cmala
That's weird. Have you checked the firewall to make sure everything is in tact? I never had that issue in the 3 years I flew it. Something is up somewhere. I would be looking for a problem instead of adding right thrust. That's the same motor I used and should be mounted the same way.
It's been that way since the Madien and I have just delt with it only thing different than when u had it and now I got it is a different prop
Ok the one washer really helped now ill just test it out some more before I make a permanent ply spacer on the cowl so that the spinner will line up correct again
