[MENTION=81]Ken Man[/MENTION]... I see two new motors on the subsonicplanes.com site and was wondering, again, about the prop and voltage restrictions, as well as Kv options
First, are there other lower Kv options available for bigger props on the DM5320?
Second, are these listed volt and prop restrictions just about heat, or are they also about precession? It seems like the DM5320 is good to 103A from the volts and Watts listed in the suggestions, and I was wondering if it would be safe to try prop and voltage combinations as long as I remain under 103A and maybe 155 degrees F? I guess the main issue is angular momentum. For example, I can hypothetically use a 12S setup on the DM5320 with a 21x10 prop to only 90A if a 210Kv was available, but I'm not sure the motor can structurally handle a 21 inch prop to the potential 7750 RPMs in hard 3D, even if I can keep the temps down under 160 degrees.
Finally, the DM5335 says "For hard 3D flying keep the prop to 19" on 8s and 20" on 6s". But a 24x10 on 12S is probably the smallest prop needed to get anything close to 4800+ Watts on a 189Kv motor.
Thanks for any info you can provide to help clear this up.
