Bipeguy03
Chugging away on the top wing. I got the cabane mounts finished, the wing trammeled and the bolt holes drilled. I just tapped the wood block for now because I haven't made up my mind whether or not I want to use blind nuts. I'm using a 1/4-20 bolt, they are most definitely over kill but trying to keep the amount of tools needed for field assembly to a minimum.
The front mount. I put a balsa block on top of the mount block and sanded it flush to the ribs, after I sheet the bottom of the wing I will back drill the holes, then set the wing on the cabanes and trace the tab foot. I will then cut the balsa away down to the ply mount, leaving a recess for the tab in the wing. Should make it easy to get all the bolt holes to line up, and speed up field assembly time.
Got less than 1/4 of a degree of negative incidence in the top wing and 1-1/2 degrees of positive incidence in the bottom wing.
Putting the tip bows in!
Starting the sheeting, doing the bottom sheeting on the wing first as all of the tabs and mounts will protrude out of the bottom (they protrude through the top in the bottom wing).
Putting the notch in the tip bow for the tip sheeting to rest in.
Tip sheeting on. With the sheet recessed into the tip, after it is shaped and rounded the sheeting will be nice and flush, and make a nice smooth tip for covering.
Really happy with the symmetry, the bottom wing is laying on the top wing and the tips match pretty good!
