Bipeguy03
I tweaked on the rib shape just a little, it has always been semi-symmetrical airfoil but the shape that it was on the original plan would have been a PIA to build as you couldn't pin any spars to the board without shimming them. So I flattened the bottom out just 3/32" and now I can build the wings by pinning the front and middle spars to the board, glue all the ribs in, put all 3 top spars on, and then when I've taken the wing off the plan I'll only have to install the bottom rear spar.
I do believe the second sheet of the plan is finished! So sheet 2 has the wing, all of the formers, cabanes (with the former drawing), "N" struts, horizontal tail, and the ribs.
Time to finish sheet 1. I still need to tweat on the position of the lower cabane mout. I also need to tweak on the vertical tail shape as it just still doesn't look 100% right to me. Then I have to finish drawing in all the details and label things, and finally finish the Landing gear design.
Then it's on to building!!!
